Issues since the latest update
293
06-05-2026 01:41 PM
RuimengPang
Field Maps have been acting odd since I started noticing the changes from the new update.
There seems to be more restrictions on field entering, offline map download size...
Earlier I had trouble downloading a layer to the map and the log showed "error code 21 invalid json" but in fact it was for the size of the download. I disabled attachment download and used a local basemap from the device and the maps downloaded successfully. Not sure what the code 21 was really about.
Right now I'm experiencing not being able to insert a new record on a mobile device from "The form contains unsupported data" while I'm not too sure what the unsupported data is.
In fact I deleted the form items one by one and saved to map to see what was causing the problem and I it was still letting me add anything when I only had the last form item left (it's just an integer switch).
These seem to be new issues that I haven't encountered before.
Has anyone else noticed any odd behaviours from Field Maps recently?
