Is it possible to get device location without Internet access? If yes, then how ?
917
09-06-2024 04:12 AM
Ashok
Dear Community,
I have a requirement that, I would like to get device location and store it in assignments layer (in some test field) on submitting the assignments. And I need this in offline (without Internet access).
Please note, not the feature location, I need device location when I submit/complete the assignment.
Please let me share some ideas or process , how to get it done.
Ashok
Y_Chau
@Ashok This could be what you are looking for - https://doc.arcgis.com/en/field-maps/android/use-maps/track.htm
DougBrowning
MVP Esteemed Contributor
Is it Android or iOS?  Most Samsung tablets have a GPS in them so they will work fine.  iPads have a dual chip GPS and cell so in order to have GPS chip it must be a cellular tablet.  You don't have to enable cell just must have the chip.  A WiFi only iPad does NOT have a GPS chip.  This could be what you are seeing. Need more info.
Ashok
Dear @DougBrowning , Thanks for your reply. I am using iPad WiFi only tab.
But I was asked to switch on the location when I opened my project in Field Maps app. And I can also see location option in app settings -> Field maps settings.
Please check the below pictures for reference.
And I observed, in offline new tracks records are inserting in Tracks layer of TrackView that we created and configured in Track Viewer portal app.
But here my only concern was, I wanted to get the User/Device location when he submits the assignment or when he opened the assignment to fill the survey form in Field maps app. In online(when Internet is available), I got succeed. In order to achieve that I have added "Last Known Locations" layer (of TrackView) in my Field Map Project. And I am able to get the latest user/device location by using the following Arcade expression, and I am using this expression for one of the Field's Calculate expression and displaying the Result.
//Start
function MetersToLatLon(x, y) {
    var long = (x / 20037508.34) * 180;
    var lat = (y / 20037508.34) * 180;
    lat = 180.0 / PI * (2.0 * Atan( Exp( lat * PI / 180.0)) - PI / 2.0);
    return{
        y: lat,
        x: long
var serverlayer = FeatureSetByName($map, "Location Sharing - Last Known Locations")
var loggedinuser = GetUser($layer).username;
var lastediteduser = null;
var userGeometry = null;
for(var user in serverlayer){
  if(user.last_edited_user == loggedinuser){
     lastediteduser = user.last_edited_user
     userGeometry = Geometry(user);
    break;
var latlon = MetersToLatLon(userGeometry.X, userGeometry.Y);
return Round(latlon.x,6)+","+Round(latlon.y,6);
//End
In order to achieve same thing in offline, map should be offline enabled, so that map can be downloaded in FieldMap app for offline use.  But I am getting an error that "The feature layer view is created from a layer that isn't sync-enabled".
I understood that the feature layer "Last Known Locations" Sync option is disabled. This layer is created as Feature Layer (hosted, view) and actually created by system when we create a project from Track Viewer app. And there is no provision to make Sync enable for this layer in Portal item settings and in ArcGIS server settings.
I think, if I can resolve the above error, I may get succeed in offline map also
Please suggest how to resolve this issue or any other process.
Ashok
DougBrowning
Yes the iPad will try and guess your location from WiFi and often it was use the last location it had - but it for sure has no GPS chip.
