The new Field Maps update now has markups showing as one Personal Markup. Prior to the new update, I had individual markups that I shared with coworkers that I was able to rename and toggle on/off in Field Maps. Now they are all showing as a single Personal Markup and overlapping one another across my maps. I would love to be able to toggle on/off individual markups, rename them, etc. as I did prior to the update. Not only are they overlapping, but I cannot see how things are labeled unless I click on each items individually which is inefficient. Esri, please fix this or offer a solution. My locally saved markups now displayed as a single Personal Markup are useless now. Has this affected anyone else's workflow or have you found a workaround?
The consolidation of markups into a single personal map and the simplification of the labeling has also impacted my team's workflow. It affects our ability to separate and share markups that were created on different days or for different projects because they overlap. It is impossible to distinguish one from the other.
We had done some research with customers about markup and have iterated on the design, but as we learn more from customers like you, we can keep evolving it.
So thank you for sharing - we'd like to log all your use cases. If you don't mind, please take this markup survey , where you can also indicate if you'd like to have a follow up meeting with us to discuss your needs. This can help us prioritize how to enhance the tool in future releases.
Hi Lisa, I'm having a similar issue loading the .markup files into arc gis pro is there any feature to assist with this
