How to access and edit Survey123 records from Field Maps
309
02-13-2025 01:52 AM
BenBlowers2
Hello
I am trying to access existing Survey123 records from Field Maps - click on them and open them up in Survey123 for editing. However, when I click on the Survey123 record within Field Maps, it seems to open a new record for submission rather than the existing record for which I have just clicked even though the globalID has been used. I have tried disabling and re-enabling editing on the item details page but that has not helped.
Any help greatly appreciated!
Ben
DougBrowning
Have you looked at this page https://doc.arcgis.com/en/survey123/get-started/integratewithotherapps.htm
You did not post the actual URL you are using so not much to go on here.
