I am not sure if this is the correct community to post this question but I thought I would start here.
Is there anyway to have the settings from the GNSS and Field Maps populate into the metadata. The other day I noticed settings were changed when a new field member was using the GNSS. We are currently using an Arrow 100+ GNSS. Within the GNSS settings you set up a profile that includes antenna height, GNSS coordinate system and map coordinate system. Having those settings along with the field maps location profile populated into attribute fields would be a huge help to verify how the data was collected.
