Get logged in Username
5358
03-13-2023 08:29 AM
BrianBulla1
Just back from the Dev Summit and thought I'd start diving into FieldMaps.  So I'm creating my first form and want to AutoPopulate the "USERNAME" field with that of the logged in user.  I'm assuming I need to use Arcade to do this, but I have no clue what the code would be.
In QuickCapture this was super easy.  Can anyone advise?
Thanks!
BrianBulla1
OK, I figured this out.
GetUser($layer).fullName
BrianBulla1
DanielMiranda2
Be careful with this if you plan to take Field Maps offline. FullName, FirstName, and LastName do not work while offline. username however, does work.
SolanaFoo2
Would be nice if they fixed that...
ADS
Another configuration would be to enable editor tracking in Map Viewer, which I believe adds the fields: [Creator, Creator Date, Editor, Edit Date] to your feature layer where you want to add/edit features. These fields populate from signed in AGOL or Enterprise Portal user credentials.    After you enable editor  tracking, to add the fields,  you can then configure and utilize the fields in Field Maps Designer form view and elsewhere.
BigLouC
I used this from another post, in my case, I needed to strip only the userID number part from the whole text as the field I was populating was a number field.
var p = Portal('https://www.arcgis.com');
var textfield = GetUser(p);
var numbers = "";
for (var i = 0; i < Count(textfield.username); i++) {
    var char = Mid(textfield.username, i, 1);
    if (IsNan(Number(char)) == false) {
        numbers += char;
return Number(numbers);
