Filter Multiple Layers
1026
05-18-2025 01:16 PM
MeleKoneya
Good afternoon,
I have two layers in my map created by filtering the base data in ArcGIS pro when publishing.
I'd like to make it easier for the users to filter the two layers but for now, it seems they have to select each in the table of contents and apply the attribute filter.
I have also tried to symbolize and group the data in Map Viewer using one layer, but that has not resulted in what I'd like to achieve as Map Viewer does not make it easy to symbolize on multiple attributes.
Let me know if you have any insights on how to filter two layers at once in Field Maps.
Thank you,
Mele
fjramos
I kept thinking about this a while back, but always forgot to ask if its possible here. I think it would work (not sure how hard it would be to inpliment), but the layers would have to have an identical field. for example, maybe fields in the metadata like creation date, edit date, creator, editor and/or fields added by the user but they would have to be fields typed exactly the same.
