Hello.
I am using ArcGIS online and ArcGIS Pro on my desktop.
I have added some layers (contours and waypoints) to my map on ArcGIS Pro and shared this map as a weblayer to my oneline ArcGIS. I used Fieldmaps to create offline areas for taking into the field. I do this all through ArcGIS online.
It has worked fine for the Waypoints. I went back and added the "contours" layer, made sure everything was enabled (offline areas, sync, etc) and shared with my organization), yet when I go to download an offline area in my Fieldmaps App on my phone, a strange long rectangle shape appreas. It doesnt matter how big I scale it (room, rooms, buildings etc) the strange rectangle shape just gets longer...not wider!
Any one had this problem before?
I cant seem to get the offline are big enough (wide enough) to download a suitable area?
It was working fine before but now that Ive added another layer (contours) its no longer working...
any ideas?
Any help much appreciated.
Cheers,
Kay
Can you share a screenshot of what you are talking about please?
Are you referring to this
Hi @KayWeltz
Unfortunately, the screenshot did not come through can you try again, please?
Exactly the same issue here. I don't understand why this would happen, I inspected the Web Map specifications in the AGO Assistant, I inspected the Field Maps Configurations in the interface and as a json, I tried adding an offline area in AGO to see if this resets the shape. I'm clueless.
I'm on iOS 18.6.2, iPhone 10(r), Field Maps 25.1.0 (build 1141)
