Field Maps
760
02-07-2023 09:05 AM
BradSmith11
How do I transfer my working arcgis map to field maps?
AdrianWelsh
MVP Honored Contributor
Hi Brad, this article should help you get started in sharing your map to field maps but there may be a step or two before this. However, see if this helps:
https://doc.arcgis.com/en/field-maps/android/help/deploy-your-map.htm
It may also help to post this question in the ArcGIS Field Maps questions place:
https://community.esri.com/t5/arcgis-field-maps-questions/bd-p/arcgis-field-maps-questions
