Field Maps - trouble with editing initial point taken
86
Tuesday
CassidyWheat
When I use Field Maps on my phone to take a point, the initial page is a list of weeds and I’d like it to be the blank form I created/have the option for "survey point". Any idea how to change this?
EmilyGeo
Hi @CassidyWheat
It looks like those are the templates you can choose from. They appear to be based on the common name of the plant you are mapping. You can choose the appropriate template, and then the form will open. If you want to manage which templates appear, check out this article for more information on how you can add/remove/change them in Map Viewer https://www.esri.com/arcgis-blog/products/arcgis-online/data-management/optimize-templates
