Field Maps not producing search results when using an MMPK with a locator while offline
1917
06-09-2021 12:43 AM
StefanBrandt
Hey,
As per the title, I have created a mobile map package with an ArcGIS Pro made locator for use in the Field Maps app. This is because my users require a map service that always works even when offline and need to be able to quickly and reliably search for addresses
When the app is online it all works fine, since the app accesses the standard ESRI geocoder. But when I am testing the app by turning off my internet I no longer get any search results when I search for any of the street addresses despite the map package containing the necessary locator.
Any help would be appreciated!
Tags (3)
by Anonymous User
Not applicable
Greetings,
What kind of locator did you build in Pro? Did you use any custom fields when you built it?
StefanBrandt
I used the "Create Locator" tool, to create a Locator based on Point Addresses taken from street addresses in an attribute table.
