Field Maps Form View last value entered for a field
1892
12-08-2021 04:49 PM
kmsmikrud
Hello,
We have a rating field in a form. The request is this value is populated for the first entry. For the next entry, is it possible to show the last rating value entered for an observer either in that field or some other way or have it populate with the last value?
In an ArcPad project, the rating value was populated and then all following values defaulted to the last value until the observer changed the rating value.
This would be in an offline map.
Thanks in advance,
Kathy
Kanin
by Esri Contributor
Hello,
ArcGIS Field Maps do support the use of reusing recent values. Please see if this would work for you:
GUID-A9E5362B-3D9B-4E14-8830-DDDE0104207D-web
Fill out forms—ArcGIS Field Maps | Documentation
Best regards,
Kanin
If this answer solved your question, please mark it as "Accept as Solution" to help others who have the same question.
Kanin
by Esri Contributor
Hello,
Best regards,
Kanin
kmsmikrud
Thanks @Kanin !
I didn't realize recent values would show up. I'll take a look. Is there currently a way to have the value default to the last recent value offline or show it in the form populated?
I will let the surveyors know of this option.
Thank-you for the info,
Kathy
AYamaguchi_UGRWCD
Hi @kmsmikrud ! Did you ever figure out if it's possible to autofill a field from last input? Or do we still have to open the dropdown to view the 3 recents + whole list?
