Field Maps - Constraint Attribute Rule - Offline and Sync
856
03-11-2024 07:48 AM
LanceKirby2
I have a Constraint Attribute Rule setup in ArcGIS Pro. I am running Enterprise 11.1 and have a feature service referencing data in an Enterprise Geodatabase. This constraint rule validates some data when a user submits a record through Field Maps and returns a custom error message if the data isn't valid. The validation works great in a "live" map within Field Maps and returns the full error message. When the data is offline and synced the validation appears to work as the record isn't allowed to be submit, but it only returns a generic error message. Is this the intended behavior or am I missing something?
