Field Maps & ArcGIS Pro
920
11-10-2024 03:11 PM
briganttine
So I am new to Field Maps. I created a map for Field Maps and created a form the way I want but when I opened the map in ArcGIS Pro, all of the extras I put under each layer is not showing up in Pro. For example, it shows the fence line layer but the 'notes' and 'types of fences' I plugged in as a 'Radio Buttons' choice are not showing in Arc Pro. Am I supposed to create a new map in Arc Pro with a gdb and all the layers I created in Field Maps first before I set up Field Maps?
If not, then how come my form elements aren't showing up in ArcGIS Pro?
ChristopherCounsell
MVP Frequent Contributor
Forms are currently not supported in ArcGIS Pro. They are limited to Map Viewer, select web apps and Field Maps.
https://community.esri.com/t5/arcgis-pro-ideas/smart-forms-conditional-visibility-in-attribute/idi-p...
ChristopherCounsell
