In the new Field Maps update, the system fields have disappeared (create_date, create_user, change_date, change_user and so on) . They were previously visible by default.
You can add them back in the browser in "Map Viewer" in the pop-up settings, but they are not available in the fields in "Field Maps Designer". Now you have to open two web applications to configure all the input fields for Field Maps. This is not a good solution.
And it does not transfer the date setting to the downloaded offline areas.
See attachments.
The date and time format is very unusual for the rest of the world and is only used in the US and causes confusion. Please add a ISO Date setting with YYYY MM DD again.
Hi @CeBe
Our field workers are reporting the same issue after the recent FieldMaps update. I have tested this and can see that in FieldMaps 25.1.0 the pop-ups for related tables show the Created By field at the top, but in FieldMaps 25.2.1 the Created By field is not shown on the pop-up. This was helpful for our field workers to quickly see what items they had created.
Hi @CeBe the team is looking into these issues. It would be helpful to reach out to Support and attach yourself to the existing BUG(s) for these behaviors. I am aware of this one for the last edit summary: BUG-000179946
I am not sure of the status of the date formatting but Support can help track that down. Thank you!
