Field Map tutorial that uses EGDB feature service layer
6984
18
05-24-2024 07:34 AM
dsinha
Hello,
I am trying to create a Field Map app for my organization for data collection. I want the app to use a feature service generated off a feature class in the organization's EGDB. Are there any tutorials/demo videos/webpage where there are instructions of how to go about doing this?
I am the DB and EGDB admin for my organization but I keep getting error messages in the  Forms dialog box essentially indicating that I do not have edit permission on the feature service and all the form elements are greyed out.
Any help would be appreciated.
Deb.
HannesVogel
If you disabled Pop-ups for one layer, it looks like this when you right-click the layer in the contents area of your map:
When you enable Pop-ups, it looks like this:
dsinha
@HannesVogel Thanks for that suggestion! I was troubleshooting with an ESRI analyst yesterday and it seems the problem might be with the EGDB itself where the feature layer resides. I will report back when we are able to identify what exactly caused this problem.
dsinha
After almost 2 weeks of conversations and tests, the ESRI analysts discovered that it is not possible to use a feature service for Field Map-based data collection. It has to be a hosted feature class.
Thanks for the help everyone!
HannesVogel
It would be interesting why it is not possible for you / your configuration. In general, it is a possibility ESRI provides and it also works to edit in a referenced enterprise geodatabase and not only in hosted data. But maybe those information are too sensitive to share.
dsinha
Upon further discussion with Esri Analyst, I learned that the Form Elements (in the Field Map Designer) remain inaccessible at this moment when using feature service. Hypothetically (not confirmed yet), use of Fields to design form would work.
drWood
Did you ever get this to work? The analyst you spoke with is incorrect that feature services cannot be used within Field Maps as my dep has been using that specific setup since before I was hired in 2022. Maybe there's a specific part of the configuration or registration with them that is causing issues? I'd be happy to help get your resources configured if you still need aid.
snelson
Hi, we are encountering this issue now-- any insights? Our editable feature service appears greyed out within Field Maps as well.
drWood
Is this a new service or one that has been functioning without issue previously?
dsinha
Hello @drWood, thanks so much for your offer to help. Based on the experience, I decided to not go the EGDB route given the small size of our organization and small number of GIS editors. The EGDB option just seemed way too complicated in our situation.
