Fetch Attribute From Nearby Feature on Field Maps
2614
08-09-2022 10:46 AM
KatiePiper
I have been trying to do the fetch attributes from nearby features arcade code that I have seen on blog, github and various other community posts by @Anonymous User . I cannot get it to work for my field map.
// If feature doesn't have geometry return null
if (IsEmpty(Geometry($feature))) { return null }
// Get the parcels layer
var parcels = FeatureSetById($map, /* Yurok Addresses */ "17d69e9a280-layer-9")
// Buffer the current location and intersect with parcels
var bufferedLocation = Buffer($feature, 3000, 'feet')
var candidateParcels = Intersects(parcels, bufferedLocation)
// Calculate the distance between the parcel and the current location
// Store the feature and distance as a dictionary and push it into an array
var featuresWithDistances = []
for (var f in candidateParcels) {
    Push(featuresWithDistances,
            'distance': Distance($feature, f, "feet"),
            'feature': f
// Sort the candidate parcels by distance using a custom function
function sortByDistance(a, b) {
    return a['distance'] - b['distance']
var sorted = Sort(featuresWithDistances, sortByDistance)
// Get the closest feature
var closestFeatureWithDistance = First(sorted)
// If there was no feature, return null
if (IsEmpty(closestFeatureWithDistance)) { return null }
// Return the address
return `${closestFeatureWithDistance['feature']['ADDNUM']} ${closestFeatureWithDistance['feature']['ADDRESSNAM']}`
 I get the error "failed to calculate" every time. We are surveying for water tank placements and trying to make it easier on our fieldworkers. If all else fails, I will have them write it in or create a domain but would prefer to have it auto populate.
Should I change "ADDNUM" and "ADDRESSNAM" to something within my layer? Attached is a list of field names for my Address layer. I could just use "Full Address" or "Label" instead of "Address_number" and "StreetName"
I read on one post that it could be because of the spatial reference but that was supposed to be fixed in the last release and I am not getting that same error message. I am still fairly new at Arcade but was able to implement a code for the child table auto population from this parent layer. If I can get this next one to work correctly, it would be incredibly useful in other projects.
anonymous55
Hello
You just need to change this line of the code
To this
return `${closestFeatureWithDistance['feature']['Address_number']} ${closestFeatureWithDistance['feature']['StreetName']}`
also you need to paly with buffer number to get result.
