Fetch an attribute from a related record
1324
09-19-2023 06:39 AM
Sarah-CodyKnight
Hi there,
I have a point layer and three related tables in a collection map on Field Maps. In the form of one of the tables, I want a text field to auto fill based on what's in a text fields in the point layer. I'm brand new to using expressions in Field Maps, and so tried adapting the following from one of Esri's posted examples on Common calculated expressions, but get an error in Field Maps saying "Failed to calculate". Any help would be great. Thanks.
var plants_sept_source = FeatureSetByRelationshipName($feature, 'Sept_Measure_Butternut_data_sheet', ['current_plant_source'], true)
if (!IsEmpty(plants_sept_source)) {
return plants_sept_source['current_plant_source']
} else {
return null
I've also tried the following, with no luck.
var related_features = FeatureSetByRelationshipName($feature, "Sept_Measure_Butternut_data_sheet", ["current_plant_source"], false)
var related_feature = First(related_features)
if(related_feature == null) {
    return null
return related_feature.current_plant_source
DougBrowning
MVP Esteemed Contributor
I am not sure you will get null at all.  What I do is use count like this.
if count(related_features) == 0 {
     return "none found"
else {
return First(related_features).current_plant_source
Note syntax is not perfect but I hope you get the idea.
