Failed to Download Offline Area
952
05-13-2022 06:23 AM
JosephHilliard94
Hi there,
I am sure some of you have the frustrating issue where offline areas fail to download for no apparent reason. I have trawled the community on this issue and there doesn't appear to be a concrete solution for this. On some maps, offline areas work fine, on others, with the same settings, they fail. Any ideas?
Thanks!
Joe
TravisSizemore
Hi Joseph,
This has been the million-dollar question lately. If you search for this question there are various posts with theories. I think the leading theories 1) are a layer or relationship with corrupt or incompatible JSON causes it to fail during creation and 2) a server timeout during download causes it to cancel (since large files tend to download more than smaller ones). I think a lot of people would like it if ESRI put a team on fixing this, if they aren't already. This is a critical feature for many people who work in remote areas. I know that we spend hours each season creating map packages to side-load because of this issue. Hopefully someone out there has some updated information on this issue.
Good luck,
Travis
JosephHilliard94
Thanks for your workaround, been a nightmare recently so appreciate the reply!
JosephHilliard94
Just to follow on if anyone is interested, the issue is that contingent values do not work offline. Thanks!
