Enterprise connection in Field Maps
1470
01-14-2025 10:15 AM
jmendi
Our Enterprise Portal is only accessible via smart card readers, but I have never attempted using our Enterprise with Field Maps. We use Juniper Systems devices which offer smart card readers, but we have only ever used the systems with our AGOL, and we do not currently have any devices with smart card readers.  If we were looking at getting these smart card readers to connect to the Enterprise Portal via Field Maps, would you not be able to work offline? Are you required to be connected through the network on a secure Wi-Fi connection?
MiaogengZhang
After you sign in with smart card, You could take a map offline.  Then you can work without network connection and sync back online using the card.
MiaogengZhang
jmendi
If someone is in the same boat as me and needs users to have certificates such as a smart card to sign into your Enterprise, there might be a workaround to creating SAML certificates (username and password) for single sign-on use.
