editing does not appear on iphone
821
06-17-2025 08:36 PM
yockee
I recently update the form on Field Map. I just add a textbox to be filled with texts.
Then I test it on Android and Iphone.
The editing symbol is not showing up on Iphone. The Androids are working fine.
I also test using another newly developed Field Map with basic functionality. The same result occurs : editing button not appear on Iphone.
What seems to be the problem ? It was working previously on iphone without problem.
I am testing on : Iphone 12 promax, 14 promax, 16 promax with IOS 16.3 and 18.5
KerriRasmussen
Hi @yockee . I'm sorry to hear you are having an issue with ArcGIS Field Maps. What version of Field Maps are you using? And are you able to edit other maps on your iPhone?
yockee
I have to restart the arcgis server and re-assign all permissions. It works normally now.
