Deleting multiple features in one layer
1585
05-19-2022 07:57 PM
MichelleMartin15051
I have a feature layer in a map which includes a whole cluster (301 to be exact) of features which need deleting. Can this be done with Edit Multiple Features? If not, how should it be done?
nspittlemeister_LCFPD
If you have ArcGIS Pro you could add the feature service to Pro, select multiple features and then delete them using the edit tools.
ColinLawrence
@MichelleMartin15051 Edit multiple is only used to modify feature attributes for existing features of the same layer; unfortunately you cannot delete using this method. The most effective method is likely to use Pro as suggested above.
Regards,
Colin
