Hi - We are using Field Maps to collect data about marshes along the shoreline. One of our layers is Marsh (polygon field). Users delineate the boundaries of an existing marsh area as a polygon in the app. We also have a feature layer called Planted Marsh where a user draws a polygon around areas of a marsh that have been planted. Each of these polygons has different fields and forms attached the them.
A planted marsh polygon can sometimes be the same area as a marsh polygon (i.e. The entire marsh area has been planted). In these cases, is it possible in Field Maps App for a user to copy an existing marsh polygon from the Marsh layer and paste it into the planted marsh layer as a new feature and then fill out the form to fill in the attributes of the planted marsh area? I haven't been able to do this, so I figure no, but thought I would ask just in case there is a way.
Thank you
