Create Link to Open up Field Maps App with Specific Map | referenceContext Parameter?
2160
06-05-2024 12:17 PM
ArmstKP
Is it possible to create a URL that opens up Field Maps with a specific map loaded, but not zoom to a specific feature to edit.
Is there a referenceContext parameter for just doing this?
JakeBrownMaps
Hello @ArmstKP  - yes - the format is
https://fieldmaps.arcgis.app/?itemID=<item_id>&referenceContext=open&portalURL=https%3A%2F%2F<org>.arcgis.com
If you use Field Maps Designer you can find this link in your share tab
Screenshot 2024-06-05 at 3.23.55 PM.pngScreenshot 2024-06-05 at 3.23.55 PM.png
Also there is a video that talks about it around 5 minute mark (whole video is worth a look)
https://mediaspace.esri.com/media/t/1_0rni05by
You can find more documentation here: https://doc.arcgis.com/en/field-maps/latest/prepare-maps/deploy-your-map.htm
Hope that helps
-Jake Brown
Product Engineer
Field Maps Team
JakeBrownMaps
Hope that helps
-Jake Brown
Product Engineer
Field Maps Team
ArmstKP
@JakeBrownMaps Thank you so much for this information!!  I had no idea that existed in the Field Maps Designer!
