Copy Attributes to a Read-Only Field on Form
599
05-02-2024 05:06 AM
RobertAnderson3
MVP Regular Contributor
This is my first foray into using the Field Maps Form Designer (Survey123 has been my bread and butter) and I'm looking at how it behaves when you copy a feature to create a new one. I'm looking at making a Workforce-esque Field Maps set up, by showing work that needs to be done and for a supervisor to create new work off of existing assets.
Some attributes on the feature I copy are something I would not want edited by the user, such as Asset ID or the Address. It seems like if the field on the form is set to read-only, then the attribute from a copied feature does not fill in that field, is there a way to make this work?
Alternatively, is there a way I can make this field visible to some users, but only editable by others? Would this require creating two separate Field Maps maps?
HannesVogel
Hi @RobertAnderson3 , i can only try to answer your last question - yes I think you need 2 maps to achieve different permissions.
