Configure Minimum Capture Accuracy for Map via Field Maps Web App
1250
06-01-2021 01:33 AM
Chris_Whyte
Currently trying to configure a map on the Field Maps Web App to have custom collection settings, specifically I want to set the minimum accuracy requirement at the map level rather than on the device.
This article states that it is possible by accessing the Field Maps Web App settings section, I cannot locate this option on an enterprise 10.8.1 portal:
https://doc.arcgis.com/en/field-maps/android/help/configure-the-map.htm#ESRI_SECTION2_99AF2CDBD36E46...
Does anyone have experience with this function?
Cheers!
Chris
by Anonymous User
Not applicable
This functionality was added to the Field Maps web app after the 10.8.1 version was released. There are no plans to release another update for 10.8.1. Those settings are available in ArcGIS Online today and will be available starting with Enterprise 10.9.1.
