Conditional Visibility and Arcade expressions
3231
02-18-2021 12:41 AM
LouiseHarris1
I am new to Field maps and Arcade expressions and am having issues trying to create an expression that will show a question or set or questions based on the answer to a previous question. So if they answer poor to the condition of the asset I want them to see the question that asks if it requires an urgent repair. I used the following expression but instead of showing the question about urgent repairs it didn't show it. It seems to work the opposite to expressions in Survey123 Connect.
$feature.Condition != "poor"
Can somebody let me know what expression I need to use.
Also is there any documentation that explains how to put arcade expressions together and what different expressions do/mean?
Thanks
Louise
Ewout_de_Graaff
Hi LouseHarris1,
The != means in Arcade IS NOT. So in your case you have to use == for IS in SQL terms.
Here you will find further documentation and how-to's:
https://developers.arcgis.com/arcade/
GIS specialist bij Terra Nostra
Ewout_de_Graaff
Hi LouseHarris1,
LouiseHarris1
Thanks, that has worked.
