Cannot define a vector tile basemap in webmap
2371
10-26-2021 12:28 AM
NicolasGIS
Honored Contributor
Hello,
Currently, it seems like it is not supported to reference a vector tile basemap for offline use even if the map is configured to have a vtpk side loaded.
It's a bit annoying.
Did I miss anything ?
Nicolas
RichlandGIS
I have not tried to sideload a vector tile package, but there is a setting for this on the hosted tile layer published from the vtpk.
Once checked, I have no issues taking vector tile layer offline:
I use this since creating an offline area always packages the current basemap, even when you select the option to use the tile package the device already has.  I have a tiny vector basemap now so the offline areas don't get so huge.
by Anonymous User
Not applicable
You did sideload the vtpk to your device, then reference that vtpk by name in your web map right?
NicolasGIS
Honored Contributor
Yes the problem is that you cannot download an area if there is a vector tile layer as basemap as it does not consider it as downloadable
RichlandGIS
NicolasGIS
Honored Contributor
Completely missed that...
Many thanks @RichlandGIS
NicolasGIS
Honored Contributor
@RichlandGIS, actually, I now understand why I missed it at the first place: this option is only available if you have the related vtpk available on the Portal for ArcGIS.
As I had deleted it, it was not available.
Thanks again for your time and help: much appreciated
