Can published feature layer and hosted feature layer have a relationship class built?
1282
06-09-2022 01:14 PM
rsun_TQB
Hi All,
Can published feature layer (from enterprise GDB) and hosted feature layer (Survey123 hosted on Portal) have a relationship class built? so...on Field Maps it will show a link to Survey123 form automatically?
Reno
ChristopherCounsell
MVP Frequent Contributor
No, you cannot have a relationship class directly between a Hosted Feature layer and a enterprise geodatabase referenced feature service. There are ways you could look at approaching this.
Either service can have a related table. Either could be used to configure a pop-up with a custom URL scheme that will launch a survey. The survey could create new points, or add to a related table. Lots of options.
See:
https://support.esri.com/en/technical-article/000021198
https://community.esri.com/t5/arcgis-survey123-blog/understanding-survey123-s-custom-url-scheme/ba-p...
https://doc.arcgis.com/en/survey123/reference/integratewithotherapps.htm
ChristopherCounsell
See:
rsun_TQB
Hi @ChristopherCounsell ,
Thanks for the reply. That's exactly what I have been doing without using Relationship Class when using "Survey123" hosted feature with published feature service from enterprise GDB.
I have been utilizing custom expression with Arcade to generate URL that can pass id and lat/long to Survey123 for inspection.
I understood everything is manageable and doable, but as I have high expectation of ArcGIS Solutions... it need to be more powerful and user-friendly. Passing lat/long should be built-in feature, and passing other attribute should have GUI to make workflows smoother.
Just my thoughts.
Thanks a lot,
Reno
