Autopopulating fields from a related table using Arcade
9587
18
04-11-2023 07:39 AM
DaveK
Hello!
I'm creating a Field Maps collection form which includes a parent point layer as well as a related table. The parent point layer contains a UniqueID field which is a domain that the user will select. Is it possible to auto populate the remaining fields in the parent table from the information in the related table based on the UniqueID chosen? I think the "Fetch an attribute form a related table" from this page - https://www.esri.com/arcgis-blog/products/field-maps/field-mobility/common-calculated-expressions-fo... is the closest to what I'm looking for. Instead of populating the related table from the parent, I would like to auto populate the parent layer from the related table. Any help is appreciated.
Thanks.
ErikWalling
Hi Doug,
I have a very similar issue but just different enough so that the solution provided isn't quite the fix I need. I am trying to calculate all the values in a field based on the values from another field in a related table. Here's the set-up. The parent table Sewer_Lines contains PipeLengths for all of our sewer lines. We have a related table for flushing these lines that records each time the line is cleaned which also contains PipeLengh. Since we've already been keeping a flushing record for some time now, I'd like to have the PipeLength(s) from Sewer_Lines calculated into PipeLength(s) in the Sewer_Lines_Flushings table.  I am able to get the values this way
var flushlen = FeatureSetByName($datastore, "Sewer_Lines", ['PipeLength'])
flushlen
But this also returns the OBJECTID field, not just PipeLength. I've also tried this
var flushlen = FeatureSetByName($datastore,"Sewer_Lines", ['PipeLength'])
var feature =First(flushlen)
if (!IsEmpty(feature)) {
return feature['PipeLength']
} else {
return 0
But it returns just the first record in the parent table and not all of the records. Is there a way to update all of the records in Sewer_Lines_Flushings.PipeLength based on Sewer_Lines.PipeLength?
DougBrowning
MVP Esteemed Contributor
Not sure what you mean by all the values into a field.  You can't have multiple values in one field.
If you mean just create a string of values from the repeats then you do that by making a string in a loop like shown in this post.
https://community.esri.com/t5/arcgis-pro-questions/arcade-array-output-from-related-table-help/td-p/...
If you just want to display the repeat values then the new map viewer can do this for up to 10 records.
I think there is a way to display a table also but I forget.
Hope that helps
ErikWalling
Hi again,
I am trying to get this to work and have tried many variations without success, do you have any suggestions?
var x = ($feature.Scum + $feature.Sludge)
var y = FeatureSetByRelationshipName($feature,"MPCVRS", ['LiquidDepth'], False)
var z =First(y)
if (!IsEmpty(z)) {
    return 1
} else {
    return (x / z['LiquidDepth'])
I am trying this through a form in ArcGIS online and then going to FieldMaps to test. I am trying to calculate  capacity (sludge depth + scum depth / liquid depth). My result for var x is what I expect but z seems to want to bring along object ID and not just the value for liquid depth. The other potential issue is scum and sludge depth is being provided by user input in the form but the form seems to run the calculation as soon as the form is opened rather than after user input.... Is there a way to change that or some other work around you're aware of? I should note that capacity does not need to be calculated in the form necessarily. The other way I could do this is in the main table and possibly in the pop-up but I am not sure if that type of expression would be allowed in the pop-up or if that's more for formatting text....
DougBrowning
I your First you need to give a field name.   Like this
var tbl = FeatureSetByRelationshipName($feature, "Points", ['DesignLat'], false);
return First(tbl).DesignLat
Also First will fail if it is null so if I remember right you need to something like this.
if (Count(y) > 0) {
        return x / First(y).LiquidDepth
else {
    return 1
Syntax may be off but you get the idea I hope.
ErikWalling
Thank you for the insights! I think I finally beat this into submission. For one thing I had the wrong data type for calculating a decimal number so that definitely helped but this is what I ended up with.
var a = $feature.Scum
var b = $feature.Sludge
var c = $feature.LiquidDepth
var d = ((a + b) / c) * 100
IIf(c == 0, 0, d)
DougBrowning
Pretty sure this would crash on var d if c =0 since you are checking it after the fact.
I would do more like
iif ($feature.LiquidDepth == 0, 0, (($feature.Scum + $feature.Sludge) / $feature.LiquidDepth) * 100)
ErikWalling
Surprisingly this actually works as is. The variable "d" does not evaluate to 'true' unless variable "c" is not equal to zero. I kept getting a result of infinity which I believe was due to the calculation trying to divide by zero.
In the form liquid depth is pulled from the main table using:
var x = FeatureSetByRelationshipName($feature,"MPCVRS", ['LiquidDepth'])
var y =First(x)
if (!IsEmpty(y)) {
    return y['LiquidDepth']
} else {
    return null
Capacity is then calculated based on user entries for Scum and Sludge using:
IIf(c == 0, 0, d)
I then used:
var a = $feature.CalcCap
IIf(a > 33.0, "YES", "NO")
to determine if the tank needs to be pumped or not returning domain values "YES" or "NO"
I've successfully tested this multiple times through field maps.
DougBrowning
It may be trying to help you by working but I would not do it that way.  Never want code that divides by 0.  Its as easy fix so why not.
If I remember right var y =First(x) will also fail if x is empty  You need to check x for being empty first.
var x = FeatureSetByRelationshipName($feature,"MPCVRS", ['LiquidDepth'], false);  //faster to not return geo
if (!IsEmpty(x)) {
    return First(x)['LiquidDepth']      // or First(x).LiquidDepth
else {
    return null
RhettZufelt
MVP Notable Contributor
Depending on how complex it is, another option would be to just calculate the values in the form for the remaining fields based on what is chosen for UniqueID.
R_
