Area Calculation - Polygon Pop-Ups
1335
05-02-2023 02:30 PM
chill_gis_dude
Has anyone figured out a way to remove the area calculation that is automatically generated on Field maps when clicking on polygon pop-ups? I've attached a screenshot that shows the issue, but I believe ESRI has built into the field maps app an area calculation that I can't figure out how to get rid of. I also noticed that if the polygon is over 1,000 acres it converts it to sq miles. This leads to a lot of confusion for our older clients.
PaulLohr
I don't know the answer but here's something to consider. Have you tried switching to "A custom attribute display" with the MapViewer Classic pop-up settings or using Form Builder in Map Viewer?
I agree with you about the default area being displayed in Field Maps. Many times it is not helpful.
RhettZufelt
MVP Notable Contributor
And with points, it shows coordinate, and lines it shows length.
Been looking for a way to get rid of that for some time, no luck.  Would be nice to be able to configure a popup to only show the info you want it to in Field Maps (like in both map viewers).
R_
by Anonymous User
Not applicable
never noticed this feature before but I do see it in one of my Field Maps apps now. Curious to see if anyone has a solution.
