With the ArcGIS Field Maps 25.2.0 release, all existing offline areas have disappeared. It's likely because in the old version the offline areas were stored under: android/data/com.esri.fieldmaps/files/user@organisation_portalname, but in the new version they're now stored under android/data/com.esri.fieldmaps/files/user@organisation-portalname. (Hyphen instead of underscore) This is bad, very bad indeed... I can't expect hundreds of field workers to manually copy the data over. Will this stay like this or will it be changed back? How should I proceed?
