Allow us to access services from other portals in the FieldMaps App
441
02-13-2025 12:37 PM
Status: Open
AlfredBaldenweck
MVP Regular Contributor
Our organization has decided to use several portals. Unfortunately, this has led to some data being unavailable on our portal we use for mobile workflows.
That being said, there does exist a view on our mobile workflow portal that points to the other portal. When you pop that view into a webmap, you're asked to log in and hey-presto, your data loads.
When you bring that into FieldMaps, however, you get the following:
Domain: NSURLErrorDomain
Code: -1003
Description: A server with the specified hostname could not be found.
URL: https:/...
This is unfortunate.
I'd like a way to log-in to the second (or third, etc.) portal as necessary in the Field Map in situations like this. Bonus points if that data can then be brought offline.
I asked about this issue 3 years ago here and never got a solution, and as of today this problem is still occuring.
Accessing features copied from Enterprise to AGOL ... - Esri Community
A related (but not the same, please do not merge) Idea is to switch the active portal:
Also, not sure if there's an Idea out for this one yet (I couldn't find one so I may make one), but another related Idea would be to be able to log in to multiple portals at once and see maps from each of them all together.
I say related because it appears that making one of them work would make the rest of them work as well.
