Allow labels to be toggled on or off from Field Maps app
2187
10
04-26-2024 11:46 AM
Status: Open
Labels (2)
Geobunga
It would be helpful if the Field Maps application allowed someone to turn labels on or off for a layer where labels have been configured. There are times it is helpful for a layer to be labeled on our field maps, but having it labeled all the time is not practical or helpful. A simple toggle from the app would be nice.
10 Comments
LindsayRaabe_FPCWA
Not ideal, but a workaround that may work depending on your situation is a duplicate of the layer - one with labels on and the other off. You can then turn them on and off as required in the map layers list.
cbp-geus
We have the same issue with our field app, with not being able to turn off labels. Especially when the user is zooming out, the labels covers all the data points. Our only workaround so far is to only have labels shown at a certain large scale zoom interval.
I cannot advice to try having duplicate layers, especially if its the ones used for data collection, as this will break the app. Also, Field Maps does not support offline use for maps with duplicate layers Configure the map—ArcGIS Field Maps | Documentation, so just be aware of that.
LindsayRaabe_FPCWA
@cbp-geus yep - all very good points. To make it work offline you would need to create 2 different hosted views of the layer, not just duplicate the layer in the map. Scale intervals can certainly be beneficial to reduce that clutter as you zoom out.
ZachBodenner
Another one of those things that seem like it should be basic functionality. I don't think I am alone in this situation: A map is used in both a web Experience and Field Maps, and while Field Maps renders quickly enough usually that having labels on by default is not an issue, I really want to be able to default the labels to off in the web map for the purposes of the Experience.
jyh
Yes, please, add label toggles.  Sometimes there are limits to what you can do with symbols.  I'm working on a layer that has about 40 categories in the domain, far to many for different symbols to be understandable, especially in the field. There are times when the  field user needs to see patterns in the data, and one way to do that would be to turn on labels.
Jhuan
Because of the excessive number of labels, I couldn't see what was on the map and walked into a grizzly den. For safety's sake, can you please implement a label toggle function in Field Maps.
bsnyder83
This would be extremely helpful, please do implement this!
MWalz
Toggling labels on and off in Field Maps would be extremely useful. Even better would be also being able to change the attribute field for labels in Field Maps!
CyberForester
This is a basic function that should have been included way back in Collector. Filters are helpful to control clutter, but a label toggle is even more basic than a filter.
Kevin_MacLeod
I would suggest they add this before anything else, with Field Maps.   It affects usability so much, and it is so simple to implement - low-hanging fruit.
One reason is that I have Field version of the SDE for collection to layers with GPS in the field. So I have all the layers there from both versions.  So they can see the Default version, which gets edited by us in GIS and so it will actually have new features the field version will NOT have.  (I only have time to QA and sync the version every few weeks so they get out of sync)
First of all, webmaps should work like Pro or ArcMap with labels. Feature weights being the most vital missing capability.  Right now, let's say I have both Meters layers. And for every meter now, if it is present in both layers there is a duplicate label.  With feature weight I could make only one of them labeled.   But if it's only present in one or the other; either way, it would be labeled.  As it is now, I simply can't have labels on the main Default version of the layers.  They'll just have to click to see what it is.  It works but is not intuitive.
A good workaround in the meantime (I suppose some years down the road Map Viewer will eventually get feature weights and other Maplex type stuff)...    would a simple ON / OFF for labels.  (So I could tell users, hey, just turn labels on if the Default version of layers, if you need)   Should be fairly simple to implement.
