Add a home button to Field Maps, just like ArcGIS Explorer has. When you press the "Home" button (underneath basemaps button) in ArcGIS Explorer, a screen opens to go to default map extent as shown on attached. I need a home button to go back to the default extent like this. It would actually be better if the home button went right to default map extent. I need a home button like this in all my apps because users get lost and need to re-orient home to the starting screen extent.
Hi @nheger - there should still be an option for the Default Map Extent when you open the Basemap tool from the overflow menu in Field Maps. Is that option visible in your map?
Actually the basemaps tool just re-opens the app at the extent you last left off, but... your suggestion led me to try the bookmarks button. That button did have a link to the default extent and so that solved my "go back to Home Screen" problem. Thank you.
Glad you found it - sorry that was a typo on my part, I did mean to say Bookmarks not Basemap.
Sign in to post, follow content, and more. New here? Register for free.
