Support for Field Maps Designer on ArcGIS Enterprise
2659
6
08-08-2023 06:00 AM
JoshuaClifford1
Esri Alum
5 6 2,659
With the Field Maps Designer web app, you can streamline your field workflows by creating the maps and forms mobile workers use in the Field Maps mobile app. If you're using Field Maps Designer on ArcGIS Enterprise, the available features depend on the version of Enterprise that you're using.
The Field Maps team has created the following document so you can quickly reference which features of Field Maps Designer are available on each version of ArcGIS Enterprise: Support for Field Maps Designer on ArcGIS Enterprise (PDF)
For more information about Field Maps Designer, see the following resources:
6 Comments
zkovacs
This is great, many thanks for putting it together.
It would be amazing to have a document that includes the AGOL version too to complete the picture.
SarahSaint-Ruth
Hi @zkovacs
You can treat this document as that - as everything that's listed in it is available in ArcGIS Online today. We also have our Archived What's New so you can see what versions had what features available. If there are other reasons for such a document would be good to know.
GaryBowles1
Joshua,
When I open Field Maps in Portal (11.0) i do not have the New Map button (see image below). Do i need to register the Field Maps Designer webapp with my portal? What am I missing?
--gary
JoshuaClifford1
Esri Alum
Hi Gary,
Thank you for your comment! That's expected. The "New map" button, and the ability to create new maps and layers in Field Maps Designer, is available in ArcGIS Enterprise 11.1 and later and is not available in 11.0.
Thank you,
Josh
GaryBowles1
Josh,
Can I register the Field Maps Designer webapp in 11.0?
--gary
JoshuaClifford1
Esri Alum
Hey Gary - Field Maps Designer is tied to the release of ArcGIS Enterprise, so unfortunately there is no way to update Field Maps Designer in your instance of 11.0. To get the "New map" button, and other updates, you would have to update your entire instance of ArcGIS Enterprise to a later version (11.1).
At least I think this is what you're getting at! Please let me know if otherwise.
Josh
