ArcGIS Field Maps Patch Releases
This article will provide updates on specific patch releases by platform, with resolved issues reported through Esri support. It also includes active patch development efforts with the Field Maps and Maps SDK teams.
1. Released 10/6
- iOS 25.2.1 - BUG-000176361 - The $originalFeature function fails during feature creation while editing of existing features is successful.
- Android 25.2.2 - BUG-000179910 - 'Take photo' functionality displays a black screen on Android devices when using In-app camera.
2. Released 10/8
- iOS 25.2.2 - BUG-000179817 - Search by layer in ArcGIS Field Maps 25.2 does not return search results when a group layer from a map service is used as the search source in the web map settings.
- Android 25.2.3 - BUG-000179817 - Search by layer in ArcGIS Field Maps 25.2 does not return search results when a group layer from a map service is used as the search source in the web map settings.
Active Patch Development issues:
- Sign in:
- BUG-000179875 - Logging into ArcGIS Field Maps 25.2 using SAML or OIDC fails and returns the error message "Certificate Required" when In-App OAuth Handling is enabled.
- BUG-000179995 - Logging in to certain Enterprise Portals in ArcGIS Field Maps 25.2 fails with 400 Invalid redirect_url with redirect authentication method and with certificate error using in-app method.
- BUG-000180053 - loading pop-ups that use expressions is slow when identifying or editing a set of features.
- BUG-000179914 - Field Maps is generating error "Basemap Unavailable. The spatial reference isn't compatible with this map."
- BUG-000179866 - he options "Take Photo" or "Attach" return an error "Unable to Attach: Check your Wifi or cellular connection"
- BUG-000179924 - Utility network feature edits appear to fail to submit when edited if map contains duplicate layers (ArcGIS.ArcGISError error 1.).
- BUG-000179903 - Nearmap US Vertical Imagery layer fails to load in ArcGIS Field Maps version 25.2 with error "Invalid JSON start: < : 0.
- BUG-000179968 - selecting features on a layer with clustering enabled does not display the popup.
- Trimble: Integrated Receiver removed as location provider option after successful Trimble migration.
This list of issues and patches can and will change. Please refer back to this post frequently if you are affected by a regression from the 25.2.0 release.
