ArcGIS Field Maps 25.2.0 released!
8960
61
09-30-2025 11:43 AM
JeffShaner
The 25.2.0 release of ArcGIS Field Maps is now available! Read our release blog article and discover what's new:
https://www.esri.com/arcgis-blog/products/field-maps/field-mobility/whats-new-in-arcgis-field-maps-2...
61 Comments
emarcelloni
Hello everybody, good morning!
In our case, the login problem arises only with ArcGIS Enterprise 10.9.1 when using Android OS and the Field Maps app version 25.2.0 or higher (including 25.2.3).
I also tested it against ArcGIS Enterprise 11.2, and the login problem did not occur.
When we use Field Maps version 25.1.0, everything works fine!
WhatsApp Image 2025-10-09 at 09.23.49 (1).jpegWhatsApp Image 2025-10-09 at 09.23.49.jpeg
MiaogengZhang
@emarcelloni The log is similar to this https://support.esri.com/en-us/bug/android-users-are-unable-to-log-into-certain-arcgis-ent-bug-00017.... Is it SAML with Enterprise 10.9.1? If so, we are working on a fix for that.
JonathanEDWARDS_EsriFrance
New Explorer
Hi @ChrisDunn1,
Esri France Technical Support analyst, here.
BUG-000179817 seems to be still reproduced in Field Maps 25.2.3 on Android.
I just tested with a Map Image Layer containing a group layer with two layers, configured the search by layer on one layer. Works fine in the webmap, no result in Field Maps.
Jonathan
JohnMoore12
@MiaogengZhang that url you provided 404's.  I have users experiencing similar issues through our MDM provider, but are able to successfully access field maps on their personal devices. I have a support case open.
MiaogengZhang
@JohnMoore12 What is the case number? We are working closely with the Support on the case.
emarcelloni
Hello @MiaogengZhang good morning!
Yes, we have SAML configured in our ArcGis Enterprise 10.9.1
JohnMoore12
@MiaogengZhang  PM'd you
PiyaliKundu2
@PaulCone2 - Are your users working from the online map, offline areas (adhoc or preplanned), MMPK and/or in scenarios where they are in low connectivity or possibly completely disconnected?
PaulCone2
@PiyaliKundu2 map is online.  We resolved our issue by making a change on our end.  Our locator is custom code that mimics an Esri locator, and it seems that with this update to FieldMaps it is being more discriminating about its interactions with our locator than a standard map is. So, we had to update the API key checking that we do to work around your app update and allow it to geocode without a key.
PiyaliKundu2
Thanks for the update @PaulCone2 ! As always, let us know if you run into any other troubles.
ar_tw
@JeffShaner , after redeploying our maps after the group search SNAFU of 25.0. I'm reminded again that BUG-000149944 for ArcGIS Field Maps is still not considered a priority.
Basic search functionality is unusable, and is one of the reasons that prevents me from recommending rolling out Field Maps across our organisation.
Contributors
About the Author
I am the Group Product Engineering Lead for our Field Apps team at Esri. I work with an amazing team building out our field solutions. Please feel free to ask me anything about ArcGIS Field Maps, Workforce, and Navigator.
