ArcGIS Field Maps 25.2.0 released!
9128
61
09-30-2025 11:43 AM
JeffShaner
The 25.2.0 release of ArcGIS Field Maps is now available! Read our release blog article and discover what's new:
https://www.esri.com/arcgis-blog/products/field-maps/field-mobility/whats-new-in-arcgis-field-maps-2...
61 Comments
VenkataKondepati
Hi @JeffShaner,
Thanks for sharing the release updates and it is exciting to see the enhancements and fixes.
Regards,
Venkat
Davis_Dad23
Hello @JeffShaner ,
I am using 11.4 ArcGIS Enterprise, can i be able to download this new version, if so i am going to app store but i don't have updates for new version or seeing the new version for the download. how can we download it.
GarethBaker1
We've definitely had an issue caused today following the app update. I have logged a ticket with ESRI UK but thought I'd mention here for wider awareness. We're getting "Unable to submit - A null pointer" when editing existing records in a ArcGIS Enterprise 11.3 hosted feature service. We're able to open the same map on a device running 25.1 and it all works.
It seems to be just this specific map right now, but it's a fairly well used one so less than ideal!
ericjetter
Hello @JeffShaner,
Thank you for the new release!
Unfortunately, since today, more than 300 of our field technicians are unable to sign in to ArcGIS Enterprise using the new FieldMaps app on iOS and Android.
We are using Enterprise Login and have tested the behavior against ArcGIS Enterprise versions 11.3 and 11.5.
This issue is significantly impacting our daily operations as a utility network operator for electricity and gas in Germany. We have already opened a support case with Esri Germany (Esri Case #04012154).
On iOS, the error message displayed is: "Invalid redirect URI".
Is this a bug in the new version, or do we need to adjust our portal configuration?
We would greatly appreciate a prompt response.
Thank you!
MatthewKing
Where can I learn more about the new "streamlined experience when working with Trimble GNSS receivers" in the 25.2.0 update?
Thanks!
Gisbert61
I've found that 25.2.0 has better, more detailed error logging! It even has a 'verbose' slider.
Aside from other features I'm already very happy with this.
MaxMolello
We are also having login and major performance issues with 25.2. Tickets have been submitted but forcing a new login all the sudden is causing problems for offline workers. Also it seems on Android saved Enterprise URL's were cleared and users now need to reenter them. SAML login in certain cases also seems to not work. There are also major map layer performance problems, we're seeing 4x slower load and draw speed.
JWalton
New Explorer
We are experiencing issues as well with users signing into the Field Maps app after this release was pushed out to all users. We have about 200 field workers that use this app since we are an Oil and Gas company, and some are having to wait over an hour before it finally signs them in again using single sign-on with our organization's Enterprise URL. I am noticing that users that are not on the latest iOS Version 26, myself included, are not having the same issues that users who are the latest iOS Version 26 are encountering.
MiaogengZhang
@ericjetter  About "Invalid redirect URI" issue, as far as I know, the redirect URI didn't change between previous market version and current update. Can you share with me the troubleshooting log when you run into sign in failure? Do you use MDM?
shawnbuck8
New Explorer
I have noticed as well this morning that my profile in field maps was wiped out with this update and had to re-enter the enterprise URL and rebuild my collection profile for GPS collection.  We also use an offline "map book" for the field and there is now a gridded background that interferes with the parcel lines on my vector tile package we use.  Is there a way to turn this grey gridded background off?  old plain white backgroundold plain white backgroundnew gridded backgroundnew gridded backgroundanother gridded background shotanother gridded background shot
millerjs2
Did feature search change? In our WebMaps, searching for features no longer works, nothing comes up when queries (e.g. pipe segment IDs) are entered.
LeeIrminger4_de
Occasional Explorer
Reporting issues with SAML sign in to Field Maps following the 25.2.0 release
BicycleJeffrey
New Explorer
Adding to report issues since update.
My team uses this and all who have been pushed the update are unable to view records from a Hosted Layer. They can be searched for, but they cannot be edited. We work inside a SAML system, and the overnight AGOL update seems to have broken our application.
Can ESRI provide a downgrade option?
Zrobinson_SFPUC
None of our field staff can login to Field Maps after upgrading to this latest version. This is a huge issue for us today as it's stopped field work. Trying to login with Enterprise just shows a "Sign in Error" page. Based on posts above we don't seem to be the only ones. This was also confirmed by Esri Support. Hopefully this can be resolved very soon or rolled back. Thank you!
ar_tw
Also having search issues @millerjs2
Our map is saved in 11.3, but only a Map Viewer Classic map.
Field users apps have updated before mine so I haven't been able to test it yet, but users are reporting no search results
Edit:
I've pretty well confirmed it's only affecting layers that are in layer groups:
Republishing with those layers outside the layer group - searching works. Moving one back in to the layer group and republishing and searching doesn't work on that layer
JosephGrossman
Edited: Original post was on the initial update.
Edited 25.2.1Update
After the original Android update 25.2.1. One of our field staff reported that the taking photo attachments is causing crashing on a Samsung Galaxy Active Tab 3. I got an update from our field staff and after further use seems like it caused the screen to turn back, and they have reverted to the Samsung Camera.
Post 25.2.3 Update:
The camera crashing issue seems to be mostly fixed, but there seem to be other related crashing issues with photos related to more complex activities.
  • "When editing a line and having vertices added to the line the app will usually crash when taking a photo, it will not crash if you submit the edits and then re-open the line to take the photo.
  • If the tablet is open and the screen is able to rotate the rotation will aggressively zoom out and sometimes crash if rotating too much in rapid succession.
    • This can be fixed by locking the screen and it does not seem to effect internal camera horizontal use.
  • With snapping on, when I open a line, the cursor seems to default to the last point and when tapping the button to center on me it will not leave the snapped point without first dragging the cursor off that snapped point."
ChrisBerryman
We are unable to search for features now as well.  Searching for feature layers work, but not map image layers.
LavanyaVasudevanNES
We have noticed that the Android version of Field Maps is at 25.2.1 and everything seems to be working fine.  Unfortunately, most of our users are on IOS 18, 18.7 or 18.7.1 and are having SSL certificate issues.
ToriMetz
I hope a hot fix gets implemented soon. I have a large number of field users that no longer have a URL preloaded through our MDM on iOS devices. We have also turned off our auto updates due to this issue.
JWalton
New Explorer
@JeffShaner has Esri made any type of an official announcement that addresses the issues that a lot of us are experiencing with this new version? Is there any planned fix or solutions that address the issues we've listed above? Most of my user's reported it taking over an hour for them to finally be able to get logged into Field Maps, and I had one report on Wednesday that it finally logged in after 2.5 hours of waiting. I am hoping these issues are addressed soon since this application is critical for our field users working with our pipelines.
ChrisDunn1
@LeeIrminger4_de,
We have had other users report problems with signing into SAML environments. While we investigate options for a fix, there is a workaround that has worked for others. Do you use an MDM? If so, you can include the parameter `useInAppAuth = false`. If that does not work, or you don't use an MDM, let me know.
ChrisDunn1
@ToriMetz
Can you describe what you're seeing a bit more? Are you using an MDM with the 'portalURL' parameter and that is no longer getting passed when launching the app? Or did the url show up in a list of previous enterprise urls and that list has been cleared out? What MDM environment are you using?
PaulPetersen1
We've noticed that on iPads, when going into edit mode, the Smartform only takes up about a quarter of the screen, instead of the full screen. We really, really prefer the full-screen mode, as the new quarter-screen mode scrunches the text and thus requires more vertical scrolling to get through the form. Is this configurable??? I really want to go back to the previous version's look.
ChrisDunn1
Hi @PaulPetersen1 ,
What's the size/version of the ipads you are using?
PaulPetersen1
Hi @ChrisDunn1 , the are 12" iPad Pros
JeffShaner
Thank you to everyone for reporting issues into this thread and our deepest apologies for the challenges that you've encountered with this update. Please submit issues to Esri Support if possible so that you have a case number to track and we can use the detailed information you provide to hunt down issues and fix them.
I wanted to provide you an update on some of the issues you've reported and are planning to fix and release patches for as soon as possible:
  1. Signing into Field Maps using ArcGIS Enterprise
    1. If you encounter an "Unknown error" when trying to sign in, the Portal URL may include one or more leading spaces in front of _https://. Field Maps 25.1 was more fault tolerant with the entered URL than it is with this release. Please check and remove any leading spaces. We'd also recommend providing an app link/QR code so that your users do not have to type in or try to paste the URL. If you have an MDM, consider pushing the portalURL key/value app configuration. You can find details about generating app links/MDM configurations in our deploy documentation topic
    2. If you encounter an “Unknown error” and the Portal URL and it is not the issue above, we have separately identified a Redirect URI failure. This is a regression from the 25.1 release where the Redirect URI is not being encoded in the authorize call. We are actively working on this issue and plan to provide a patch release as soon as possible.
    1. BUG-000179875 - using SAML or OIDC in-app authentication fails. If you are encountering this issue, setting InAppAuth=False is a supported workaround until we can get to a resolution.
    2.  "Unknown error" when attempting to sign into ArcGIS Enterprise.
  2. BUG-000179898 - Android in-app camera - attempting to use the in-app camera to capture photo attachments on some devices results in a blank screen. We have resolved this issue and are planning to release this fix in a 25.2.2 patch soon.
  3. BUG-000179817 - Search fails in ArcGIS Field Maps when a group layer is configured as the search source. We have identified a fix for this issue and are planning to release a patch with this fix as soon as possible. It is currently not planned for the 25.2.2 (Android) patch or the 25.2.1 (iOS) patch.
  4. BUG-000176361 - $originalFeature function fails during feature creation on iOS devices. We have fixed this issue, and it will be available in the 25.2.1 (iOS) patch.
  5. Unable to switch offline basemaps when the spatial reference isn’t compatible with the web map. To temporarily workaround this issue, create a copy of your web map and ensure the spatial reference of the web map matches the offline basemap you intend to switch to. We do not have a patch identified for this issue yet.
  6. Pop-up and form editing performance – there is a notable degradation in performance when viewing pop-ups or editing forms that have several expressions. We are actively working on a fix for this issue but do not have a patch identified for this issue yet.
Please note that the above list of issues is not a complete list. We are actively investigating and plan to resolve several additional issues. Our team is dedicated to improving quality and performance with each update.
Some additional, noteworthy changes within this release:
  • If you are unable to see the 25.2.x updates in the Apple App Store or Google Play, your device may not meet the updated system requirements.
  • Barcode entry now requires that the form input type be set to barcode. You will need to update your forms in Field Maps Designer if you have not already selected barcode as the input type.
  • Features that include true-curve segments are no longer editable in the Field Maps mobile app.
aswardwell
Occasional Explorer
@ChrisDunn1 I can speak more to Tori's issue. We were passing a portal URL parameter with MDM. After users updated the app to 25.2.0, the URL to our Portal that had been in the list of available portals was no longer there. Users could still connect to the Portal if they happened to enter their username and password again when prompted, but if the users were previously signed out or chose the Skip option, they no longer see the portal from the selection menu when they try to Sign in with ArcGIS Enterprise. The users are able to manually enter the Portal URL and connect.
MTBZuidVeluwe
New Explorer
Hello,
Since the update from 25.1 to 25.2 and today to 25.2.1. we are seeing features while the layer is off. Is there a way to reinstall version 25.1 (iOS)?
JeffShaner
We have released the following patch updates:
  • iOS 25.2.1 on the Apple App Store.
    • BUG-000176361 - $originalFeature function fails during feature creation on iOS devices.
    • An additional, internal reported issue found when working with tasks.
  • Android 25.2.2 on Google Play.
    • BUG-000179898 - Android in-app camera - attempting to use the in-app camera to capture photo attachments on some devices results in a blank screen.
    • 5 stability issues reported through the Google Play Developer Console found in the following areas:
      • Browsing for maps
      • Personal Markup
      • Authentication
      • Pop-ups
We're actively working on several additional issues you've reported with the intent to release patches as soon as possible. This includes but is not exclusive to:
  • BUG-000179817 (Search not finding features)
  • Authentication challenges (SAML, URI encoding) that we are working with our SDK development team to gain resolution .
  • Performance issues reported with pop-ups
Thank you again for contacting Esri Support and reporting your issues so we can track and notify you when we have them resolved.
Please continue to follow this community thread for additional updates.
Mattmillos84
New Explorer
Hey, a lot of my field workers are on Android version 25.2 and are experiencing an issue with a particular map which worked fine before the update.
When clicking on take photo or attach (anything) the following error is shown:
We are also now experiencing an issue where the minus sign is not available on a double type field
This error was directly after the update to the new version of Field Maps and seems to only be this map service. I have tried to copy it and the errors remain. I have tested on my iPhone and it works normally.
MaxMolello
Once these problems are fixed up what I'd really like to know is how was 25.2 in beta testing for 12 months but none of these very obvious and very disruptive bugs were noticed. Now all the sudden on release iPhone and Android, AGOL and Enterprise users, seemingly a large user base, can't do their jobs that rely on Field Maps. And there was absolutely no communication before the release that is was coming and would wipe users login info. I got the release email the morning after the update came out and just knew my week was ruined because that one little line 3/4s of the way down saying a fresh login was needed. How are we supposed to tell users to make sure they login before heading out for the day because their app reset when you didn't tell us it was happening until after the rollout?!
We've worked very hard for years with our massive user base to gain trust of Field Maps and GIS over PDFs and Avenza for their daily jobs. You've just ruined a large amount of that trust in single day because now either they just can't use it all or its performance problems or other bugs are too problematic and they've given up. So now my department and I are getting yelled at for something we have no control over and scrambling to find alternatives while the company loses money. At least with Enterprise or Pro releases we can install on dev and full test at our pace to find the inevitable dozen bugs, but this was on you to test since we have no control of apps on users devices. We're getting really tired of being bug testers. Just look at my support queue, the majority of tickets are bugs that you don't seem to have any intention of fixing on current releases, and moving to the next release just replaces them with new ones.
SanneMikkelsen
Please go back to 25.1.0!
We have so many issues on this one and so many field workers can´t do their job. It has been a struggle to get the field workers to use and like Field Maps instead of plain paper. Now they must go back to paper to be able to do their job... How do I get them to trust the app again when it is fixed?
AndrewDeLuca
@JeffShaner I saw the above comment in your post, while I understand disabling editing of geometry, my users are unable to interact with records with true curves even when attribute only editing is configured. I need my users to be able to edit attributes of records true curves and attach photos via Field maps, is that not possible anymore with this update and moving forward? I have the following configuration on my referenced web layer but users cannot edit attributes for any records with true curves:
This configuration allowed editing of attributes and attachments for records with true curves in the 25.1.X release.
ChrisDunn1
@Mattmillos84 ,
For the "unable to attach" issue you are seeing, that has been reported by others and we are actively working on a fix. If you haven't already, opening a case with support will be the best way to be informed of when there is a fix available.
For the keyboard issue, unfortunately that is a problem with Samsung numeric keyboards. We recommend installing the GBoard google keyboard and making it the default for your device, that will include the minus sign.
I hope that helps!
Chris
chill_gis_dude
Any update on when we will be able to search again? Does anyone have an immediate workaround?
Field workers sitting idle because they don't know where to go...
Where is ESRI's quality control?
chill_gis_dude
I want to add on that as others have said... We are constantly having to convince teams to trust our ESRI made products. It's not easy to get people to trust the new app and if trust were a ship, ESRI just shot a cannon ball through the mast of the ship.
JeffShaner
@chill_gis_dude our next patch will include a fix to search (on both iOS and Android).
We're working hard on fixing these regressions as quickly as we can and appreciate your having put trust in Esri for providing a solution to your organization. Hopefully we can win that back.
ChrisBerryman
@JeffShaner any eta yet on that next patch?
Also have other users reported issues with editing a layer that has a related table that has been added to the map multiple times to filter out various features via filters to group similar features?  We noticed editing errors on Field Maps, but when we remove the duplicated layers and have just one the editing works as normal.
We had gotten an "unable to submit" error.
RyanJalynskii
Occasional Explorer
Should really just roll back to the previous version and put this one back in beta until its fixed.
RichlandGIS
Don't see this reported  yet, but it appears to be changing symbology of some mapservices from 10.9.1.
My 'dashed' lines that symbolize abandoned lines are now showing as solid, active lines.
Still looks like they are supposed to in the mapviewer, but when the same map is opened in Field Maps app, not so.
Still working as expected on 25.1.0.  Too bad I wasn't able to stop the automatic install on most of our iOS devices 🙂
R_
ar_tw
@chill_gis_dude we had to publish some temporary services removing our layers from layer groups - this has search mostly working.
Agree on the work trying to convince the business to trust the Esri systems, but I've stopped trying over the last 12 months with the list of problems we've experienced.
We were starting a POC to replace our legacy in-house mobile mapping solution with Field Maps, but I'm not even going to push it or consider it an option anymore because I don't want to be the one explaining to the business why the entirety of our field crew is sitting idle.
JeffShaner
@ChrisBerryman tonight I submitted 25.2.2 (iOS) and 25.2.3 (Android) patches that include fixes for the search issue (BUG-000179817). Depending on the store approval process you could see an update tomorrow or Thursday. I'm going to put a new community blog out when they are approved so this information about patches is more centrally located.
Regarding the duplicate layer issue you mention, this is in progress with our Maps SDK team but no ETA on a resolution yet.
@RyanJalynskii the Apple App Store and Google Play do not support rolling back to previous version.
@RichlandGIS can you submit this issue to Esri Support so we can track it down please? If it is only happening with some 10.9.1 map services, we'll need to sort out what's unique about them that causes the rendering issue.
ericjetter
Hello @JeffShaner ,
You mentioned that your team is working on fixing the SAML login issue. Could you please let me know if you have an estimated timeline for when we will receive the urgently needed patch?
SanneMikkelsen
Hi @JeffShaner
I have tested our webmaps on Field Maps ver 25.2.1. A month ago we migrated our GAS pipeling data from APDM to UPDM. And we still have the old one runnning including the webmaps. It seems the old webmaps are working well and it is only the webmaps with featurelayers from UPDM that is not working. Have you maked sure the new Field Maps version are compatible with all versions of UN/UPDM?
ebwhite
Occasional Explorer
Hi @JeffShaner, some of our staff reported that "Integrated" was missing from their list of providers following the update. How do you re-add it? I was able to preserve Integrated by having it selected as my provider prior to going through the app update, but others were not as lucky if they had a different GPS provider selected.
JohnMoore12
I have reports from users that attempting to login to our AGOL portal is causing the application to crash since the update (Android 25.2.2) when using a Samsung Galaxy phone.
I have personally attempted to log in via multiple devices to our AGOL org with no issue so wanted to raise this flag as an edge case for anyone else.
Update:  more users have called in and are unable to access field maps with the platform crashing when attempting to login in.  The application will close after attempting to sign into ArcGIS Online or after putting in our AGOL org url into ArcGIS Enterprise prompt.  Users have been able to access field maps with no crashing when downloading the application outside of our org's MDM.  I believe there is a deeper issue here.  in contact with Customer support now.  Android update 25.2.3 did not resolve this issue.
ChrisDunn1
Hi @ebwhite ,
We are aware of the issue and are investigating. At the moment, it appears the quickest way to get Integrated to show back up is to simply uninstall Field Maps and then re-install it. If that is not an option let me know, meanwhile we will continue investigating. If this is blocking your mobile workers from completing work then consider opening a support case to help facilitate testing.
Chris
PaulCone2
@JeffShaner our sewer locators just updated to 25.2.2 and it appears the search BUG-000179817 has not been squashed.  Search is still not finding results By Address.  Only search By Layer works.  Effect is they have to type the entire address, so it gets found in the Taxlot layer.  By Address should give them (partial) results from our custom geocoder but it's still not working.
ChrisDunn1
Hi @PaulCone2 ,
The fix that went out for search was specifically for feature layer search in group layers. Is your map in ArcGIS Online or Enterprise? And where is your custom geocoder hosted? If you are on Enterprise, which version are you on?
If you haven't already, please open up a support case for the custom geocoder not working, I don't think I've seen similar cases come through so this sounds like an issue we weren't already aware of. Support can help begin tracking down the cause.
Chris
PaulCone2
Hi @ChrisDunn1,
Map is in ArcGIS Enterprise 11.1, using composite geocoder is there.
I'm heading out until Tuesday but will tag others to follow up.
Paul
Contributors
About the Author
I am the Group Product Engineering Lead for our Field Apps team at Esri. I work with an amazing team building out our field solutions. Please feel free to ask me anything about ArcGIS Field Maps, Workforce, and Navigator.
