order of layers in contents won't save
825
09-26-2011 09:51 PM
PaulCone
I'm working on a map that has a couple dozen layers -- some are off of a REST server (ArcGIS Server) and a few others are shapefiles that I've uploaded.  I've been working on this map for a week both in the ArcGIS.com (Javascript) map viewer and ArcGIS Explorer Online (Silverlight) viewer.  I toggle between the two for various reasons (the .com viewer is simpler and faster and displays data accurately -- the Explorer Online view is dropping data from a couple of my layers) and the Explorer Online viewer is more expedient in setting up the way the map looks.  But now if I change the order of layers and Save the map, the changes save in Explorer Online, but they don't save in the .com viewer -- the next time I open the map the order is reverted.  Needless to say, this is HIGHLY annoying.  😞  Is this a bug?  Is my online .mxd corrupt?
MikeGregotski
Hi Paul,
I'm noticing the exact same behaviour with the ArcGIS.com map viewer.  Did you ever find a resolution to this problem?
Mike
