I keep getting an error box with the message, "Failed to Import Shapefile - Invalid Shapefile."
I misunderstood the zip note - I thought it had to be in a folder
I'm currently dealing with a similar issue with a point shapefile (1 point) where ArcExplorer seems to be trying to import it as a polygon. I keep getting an error saying that a polygon must have a certain number of rings or vertices to display. The error # is 24305.Anyone encountered this? Other shapefiles have imported fine.
Hi - there's a few things that can prevent an import working - you must have all of the required files in the zipfile you import for example. There's a few tips at the bottom of the Import Shapefile help topic:http://help.arcgis.com/en/arcgisexplorer/help/#/Import_a_shapefile/01560000005p000000/I think the simplest way to figure this out would be if you can post your shapefile on the forum we can test it out.
I'm getting an error when attempting to import a shapefile that has more than 1000 points. Do you know if this is documented? For example, what are the limitations on line and polygon features as well?
I'm afraid we've seen this error message returned when the actual reason for the failure is something else. Would you be able to post the problematic shapefile up on the forum (or email directly if you prefer - I'm sgill at esri.com) so we can check out the problem?Thanks,
I'm having the same problem uploading a zipped polygon shapefile to the ArcGIS Explorer site. I'm getting the same error #24305 "...the ring does not have enough distinct points."
then reprojected them to WGS 1984; but I still get a error.
I was using Arctool box to assign a projection rather than ArcCatalog. Also, what is your best guess for a projection when you don't know it's source? The Atlanta data was from a ESRI Quick Start data set from ArcView 3.
I'm not actually sure what's causing the error in this case, I have forwarded this to the team and will post back when I know about a fix.
Can I compress a shapefile using this textbook's software?
Signed in members can post, follow updates, and more. New here? Register a free account.
