restricting the user to use the share option available with ArcGIS Explorer
1281
12-30-2010 07:32 PM
PiyushDubey
Dear All,
            If i want to restrict users to use the share options available with ArcGIS Explorer to save the feturelayer as a kml / layer file, be it possible. Pls let me know in this regard.
Piyush
AndreiIvanov
Piyush,
if you want to remove KML / layer package part of sharing and leave map content - then NO, it is not possible. If you want to remove Share functionality completely from the app, please take a look at ArcGIS Explorer Application configuration:
http://webhelp.esri.com/arcgisexplorer/1500/en/index.html#appconfig_manager.htm
PiyushDubey
Andriy Ivanov,
Dear sir,
             I have changed the setting using application configuration, but if i send the configuration file to any other person, he is able to reset the settings again. Is there any locking mechanism to avoid this. Kindly let me know in this regard
Thanks with Regards
Piyush
