"Route" not working
2303
05-19-2010 08:42 AM
TractBuilderSales
I recieve a "No Results Found" message when I try to get a route. They are all valid address that I was able to import using a CSV, so I know that Arc can find them. I have tried removing the "Return to start" and "optimize stop order", but that does not help either. Has anyone else run into this? I have attached my spreadsheet with the addresses, nmf file (i had to remane it as a .pdf so it could be uploaded, for some reason this forum doesn't let you upload projects for the application it focusses on...), and a screen shot of the issue.
by Anonymous User
Not applicable
Original User: mbranscomb
I have just tested this in the next release of Explorer due for release in the summer and it successfully added your locations as a CSV, geocoding them in the process. I was then able to add each one as a location (or rather the first 5 in my test) for the Route tool and successfully calculate a route between those location. Unfortunately I cannot test this in the current 1200 at this time.
Regards
Mike
