I am adding 3D point locations to the map, and attaching them to the surface. When I tilt and subsequently zoom in and out, the points appear to levitate above their actual locations, more when I zoom out, less when I zoom in. I realized this appears to be by design, since the point symbols are meant to be push pins (or stick pins). However, symbols like the Populated Place or Sphere have no "stick" so I figured those symbols should actually be centered on the point locations. But they appear to work the same as the push pins, resizing/moving as you zoom in and out. Is this "a Feature, not a Bug"? 😄
