John,
Thank you for reaching out on this and making the call for help. We'll have one of our Support Analysts contact you.
Best,
Monte (Michael)
I got it to finally work but not sure how. I uninstalled and cleaned everything ESRI out of the Registry. That still didn't work. (I had another problem of inadvertently replacing all the Basemaps with a map I did). But I somehow did a reset of the app (in settings, not at my 8.1 machine now). And the flickering stopped and the app worked. It may stop again as that seems to be it's behaviour. One day it works and the next time you launch it just hangs. I really would have rather kept Windows 7 but oh well. I was also wondering if it had anything to do with the graphics driver as my Dell laptop has the Intel 4000. But if you run the ESRI test to see if the app will work on your machine everything checks out. I do remember tweaking a setting on the graphics, kind of lowering the quality since on Windows 7 machines the app automatically does that. Maybe that's where it hangs on 8.
I ended task and tried to restart, and i learned what the black box was, If i am trying top open AGX-D and the splash screen is up, and I try to open a second instance, then that stops responding and the black box is related to that.
So, I rebooted, and then the first program I opened was AGX-D . . . it hung-up. . . I ended task and then immediately tried again, then it started.
If I monitor task manager while starting up, I noticed that about 35 to 40 MB of memory into startup the task just sits idle, but when it fully loads it goes higher. Something is getting hung up when starting the program.
I would really like an ESRI person to contact me about this and monitor my system remotely to observe these issues. . . Maybe they could then resolve the problems in the next release. I am on maintenance. If any ESRI rep reads this and would like to observe, please contact me at my information on file.
Best Regards,
j
Just tried to open ArcGIS Explorer for Desktop Build 2505 (AGX-D), and it wouldn't open.
While it has been about a month since I tried to open AGX-D Bld 2505 I was hoping it would work today, nope.
One interesting change I noticed was that after the splash screen had been up for a few minutes a black border appeared around it. While it certainly could have been there I don't remember the black box when it was just build 2500.
Will reboot and see if the problem goes away. . .
Karen, I know this sounds cliche' but reboot then retry to start AGX, it works for me sometimes. . .
Same thing is happening to me. I tried installing the 2500 version with Windows 8.1 and could get old maps to open. Now I have the 2505 install. It installed - well, there was an error about an F drive, but I found the setup.exe file buried in my users directory. It installed. But now when I try to open it just hangs. Sometimes if I open an old map file it will open, but it will give me that same jumpy screen. I try and change symbol settings and it just jumps back so that I cannot set anything. I'm a GIS specialist at work and they call me at home sometimes. I'd love to be able to help out from home, but I cannot get this bleeping thing to work!!!! So frustrating. No support for Windows 8.1 - come on.
I tried top open ArcGIS Explorer Desktop Build 2505 (on windows 8.1 desktop) last week during a web presentation and it just sat there with the splash screen up and wouldn't open. It was embarrassing. I ended task, started application again, same result, following the presentation I rebooted my PC, then it opened . . . ugh.
The package consists of a set of work flow driven scripts that you can use to create VM Images, deploy working sites. Future updates will be provided that add functionality to automate user work flow in the area of security, multi-node deployment, and auto-scalable configurations, among others.
trojan computer virus removal
Mark,This is feedback about 2505. I downloaded it today and installed build 2505 over 2500 on Win 8.1, but it wouldn't open, the splash screen just sat there for 10 minutes until I ended the task in task manager. I got this same result when trying to open an existing .nmf file. I rebooted and tried again and I had the same issues. Then I uninstalled, reinstalled, and retried, and again the splash screen just sits there, then I rebooted and it opened. . . shew!!Now it was working on My Dell Optiplex 3010 PC.Then I installed it on my Dell XPS 12 tablet running win 8.1 and this time I uninstalled build 2500 and installed 2505 from fresh. It hung up after install like above so I rebooted, and then it worked when trying to open an existing .nmf file.Now it was working on two machines.Then I went to a Dell Inspiron, of a co-worker, runnning Win 8.1 and installed build 2505 and he had never had any version of AGX on that machine. I had a similar experience with my tablet, except after the reboot it initially didn't work, and I tried to open the .nmf and it opened.It installed fine on another PC with Win 7, Just keeping you up-to-date I have it running on 4 machines now.Best Regards,John Nowlin
The ArcGIS Explorer Desktop 2500 setup.exe validator does not correctly validate Windows 8.1 Preview. You can still install and use ArcGIS Explorer Desktop 2500 on Windows 8.1 by doing the following:run the installer, this will download and unpack the install files on your computer. By default it will place the files in %AppData%\Local\Temp\ArcGISExplorer\2500\SetupIn this folder you can run the AllUsers.msi or PerUser.msi to install the software.-Mark
