How to add the new OSTN02 NTV2 Transformation to ArcGIS Explorer 1500
2507
03-15-2011 11:29 AM
JimSibbald
Ordnance Survey working with Defence Geographic Centre have produced an NTV2 version of their OSTN02 transformation.  Information about the transformation and the NTV2 file itself can be found at http://www.ordnancesurvey.co.uk/oswebsite/gps/osnetfreeservices/furtherinfo/ostn02_ntv2.html
The attached PDF shows how to add this to ArcGIS Explorer 1500.  I have also included my GEOGTRAN file which needs the .txt extension removed to work.  Enjoy!
JimSibbald
With the OSTN02 NTv2 Transformation being adopted by EPSG, I have changed the names of the transformations to reflect those of EPSG.  The CUSTOM transformation code must be in the range 208000 and so I have ensured that they reflect the EPSG code of 5338 and 5339 by using 208338 and 208339 respectively.
http://www.epsg-registry.org/report.htm?type=selection&entity=urn:ogc:def:coordinateOperation:EPSG::...
New GEOGTRAN file attached.
