Failed to add Geodatabase layers from SDE
3045
12-07-2010 01:11 PM
ChristinaMontoya
Greetings,
I was able to select the data I needed from the SDE database however, when I select next, I get the error Failed to add Geodatabase layers: -sdeGlendale.GISADMIN.Building_TRANS_R.  Is there a bug or are there some additional things a need to configure.  Seems to add shapefiles, and file geodatabase data.
Christina
