Error 99999: Error Executing Function (Failed to create contour)
3098
01-31-2012 06:54 AM
AngelaDwyer
I have been trying to create a contour from a large 30m DEM from (130MB is that too big?) and it always crashes at the interval I need (0.3m) it works at larger intervals (1m and higher).  I am running ArcGIS10 on Windows 7 and I have the Service Pack 3 installed.  I have clipped the raster and copied from a TIFF to a GRID and even converted the DEM from meters to feet.  I have also run the same function (0.3m) interval contour on a 30MB DEM and it worked then.
Any thoughts?? Suggestions??
Also the subject line should be 999999 not 99999 (forgot a 9)
Thanks!!
