Adding GIS Services using "Add Content..." to AGX 1700 from our ArcGIS Server fails to draw map. But adds the Layer and shows the Legend. No errors. No problems contacting and adding the Service. The same services called from ArcMap show up fine, whether internal or external to our network.
The map properties Projection settings in AGX make no difference. Publishing in WGS84 makes no change. Publishing in WGS84-Mercator_Aux-Sphere makes no change.
Is there some know bug or have I lost the plot somewhere?
Any clue would be useful. Thanks
Gear: Windows 7 - i5 32 bit - 4 GB RAM
AGX Build 1700
ArcGIS Server 9.3.1 services....
