Basemaps and Layers no longer appear in ArcGIS Explorer Desktop
7030
12-11-2014 01:35 PM
TomBuckler
When trying to add a Basemap or Layer from the Ribbon, there are no choices available in the drop down. They seem to have disappeared!
Tested on the latest 2505 build on two different networks. Is anyone else experiencing this issue?
MarkBockenhauer
Tom,
An update to ArcGIS online is not returning the expected results to ArcGIS Explorer Desktop.
As a workaround if you sign up for an ArcGIS Online account or use an existing one.
https://www.arcgis.com/home/createaccount.html
In your profile for your ArcGIS online account, set the Region to "World"
Then when using ArcGIS Explorer Desktop, also sign in using this account, and the basemaps will show up correctly.
If you set your region to United States, in the online profile, the basemaps will not appear.
All of the basemaps and ArcGIS Explorers default map can also be accessed directly from http://www.arcgis.com/home/search.html?q=owner:esri_arcgisexplorer
Mark
MarkBockenhauer
Tom,
Mark
JoeFlannery
Honored Contributor
Alternatively, go to >Add Content >GIS Services and add the ArcGIS Online REST Services URL (http://services.arcgisonline.com/ArcGIS/rest/services) then choose the map background you are looking for.
TomLaidlaw
The link doesn't work
JoeFlannery
Honored Contributor
Try lower-case "arcgis" in the URL.
Like this:
http://services.arcgisonline.com/arcgis/rest/services
